> For the complete documentation index, see [llms.txt](https://cube.ewelink.cc/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://cube.ewelink.cc/getting-started/add-devices/ewelink-wi-fi-devices.md).
# eWeLink Wi-Fi Devices
Lots of eWeLink-supported devices, specifically, those working via Ethernet and Wi-Fi can be managed on CUBE OS. Most of them work locally with your CUBE OS host, while others need WAN access due to limitations of firmware and chipset design.
Gateway devices can also expose supported devices to CUBE OS like a bridge between them.
### To use this feature:
1. A CUBE OS device running `v2.10.3` or later.
2. Internet access.
3. An eWeLink account.
### Open Add Device
Open CUBE OS in your browser. Click the `+` button in the top-right corner. Then select `Add Device`.
<div align="left"><figure><img src="https://67406449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FCnF8kmk9yw3yiy2mRerq%2Fuploads%2FcILnQcVvtAT3sJiKBZxq%2Fimage.png?alt=media&amp;token=3e8cdf6a-8404-4ab1-b5d4-04a10166a9a6" alt="" width="563"><figcaption></figcaption></figure></div>
### Add eWeLink-linked devices
On the **Add Device** page, click `Add eWeLink-linked Devices`. The built-in eWeLink Smart Home add-on will open directly.
<div align="left"><figure><img src="https://67406449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FCnF8kmk9yw3yiy2mRerq%2Fuploads%2FgBPmlkgsjKhvE1wn5nP6%2Fimage.png?alt=media&amp;token=149455d6-ce7e-4239-9133-f3dc92f97b44" alt="" width="563"><figcaption></figcaption></figure></div>
### Sign in to your eWeLink account
Click the sign-in button in the top-right corner. Enter your eWeLink account and password to log in.
<div align="left"><figure><img src="https://67406449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FCnF8kmk9yw3yiy2mRerq%2Fuploads%2FzGH9BzwnIjZmLOOdxKAz%2Fimage.png?alt=media&amp;token=c7e157c3-6c3d-4328-a4a9-92459bf5f841" alt="" width="563"><figcaption></figcaption></figure></div>
### Sync Devices
After sign-in, your supported eWeLink Wi-Fi devices will be listed. Click `Sync` to import the devices you want into CUBE OS.&#x20;
<div align="left"><figure><img src="https://67406449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FCnF8kmk9yw3yiy2mRerq%2Fuploads%2Fftjf8pVJiqLvFwcg9QdO%2Fimage.png?alt=media&amp;token=95528119-2ca9-4af8-ad00-48cc9ccb074d" alt="" width="563"><figcaption></figcaption></figure></div>
After syncing, go back to **All Devices** to assign rooms and rename devices.
<figure><img src="https://67406449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FCnF8kmk9yw3yiy2mRerq%2Fuploads%2FeNOMZR2zaSiUeOuSHrR2%2Fimage.png?alt=media&amp;token=9bbd1836-b053-4f0d-88e4-9a0e967d31c2" alt=""><figcaption></figcaption></figure>
In `CUBE v2.10.3` and later, eWeLink Smart Home is built in. You do not need to install it from the Docker page first.
GET https://cube.ewelink.cc/getting-started/add-devices/ewelink-wi-fi-devices.md?ask=<question>&goal=<user_goal>
