> For the complete documentation index, see [llms.txt](https://cube.ewelink.cc/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://cube.ewelink.cc/feature-exploration/matter-bridge-link-apps/apple-home-and-siri.md).
# Apple Home & Siri
## 1. Fresh setup
### Enable Matter Bridge
Please visit CUBE OS via browser. Click on the Matter logo on the side panel, and follow the guide to enable the feature.
<figure><img src="https://67406449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FCnF8kmk9yw3yiy2mRerq%2Fuploads%2F9lN5GFqDwLTmKVR83iSR%2FScreenshot%202024-12-17%20at%2016.37.55.png?alt=media&amp;token=aa80f174-43be-4230-8a73-2d9f1005ffa6" alt=""><figcaption></figcaption></figure>
Shortly, the page should show a QR Code and a line of numbers as keys to pair your device with other platforms.
### Scan on App
Pick up your iPhone or iPad and open the system Camera, aiming at the QR Code. When a yellow promotion came up labeled "Open in Home", tap it.
<div align="left"><figure><img src="https://67406449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FCnF8kmk9yw3yiy2mRerq%2Fuploads%2FLyyRrmwr1gzoyatPP9Mr%2F47F9274C-9D34-45A4-9ACE-EFB2D7D1AE2C.png?alt=media&amp;token=c7c328d9-1db3-4480-b9cc-ecf6b95c8977" alt="" width="188"><figcaption></figcaption></figure></div>
### Finish in Apple Home app
iOS/iPadOS will redirect you to the Apple Home app to add your devices. Feel free to rename each devices and assign rooms for them in the app.
<div align="left"><figure><img src="https://67406449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FCnF8kmk9yw3yiy2mRerq%2Fuploads%2FP02qseCQ0fLAd1TnAeP6%2F254FE7B1-D488-4722-9360-A018B59D70D7.png?alt=media&amp;token=80e20ca7-504d-4891-a31e-d46301f2ed08" alt="" width="188"><figcaption></figcaption></figure></div>
### Try out Siri commands
When you are done with naming your devices, give it a shot with Siri.
<div align="left"><figure><img src="https://67406449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FCnF8kmk9yw3yiy2mRerq%2Fuploads%2FCOMAlL0oDDakJjrsvE0O%2F50D3D0B9-C0C2-4370-8B26-01C72F304DAA.png?alt=media&amp;token=453e3c6c-7f8c-41ba-96d3-0129fc1b8aec" alt="" width="188"><figcaption></figcaption></figure></div>
## 2. Secondary Setup
If you have linked with a platform through Matter. You will need to generate the setup codes from that platform's app.
### **2.1 Apple Home**
Open the Home app and find the tile of the device you want to share.
Open the device's control panel and tap the gear icon.
In the **device settings** page, **scroll down** to “**Bridge**” and tap it.
This will lead you to the settings page of the bridge that connects your devices, scroll to the bottom and tap “Turn On Pairing Mode.”
Copy the code and follow the pairing guide on the CUBE OS page.
Please Note: This will bring all supported devices attached to the bridge to your CUBE OS.
GET https://cube.ewelink.cc/feature-exploration/matter-bridge-link-apps/apple-home-and-siri.md?ask=<question>&goal=<user_goal>
