> For the complete documentation index, see [llms.txt](https://cube.ewelink.cc/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://cube.ewelink.cc/feature-exploration/docker-and-add-on.md).
# Docker & Add-on
By downloading different Add-ons in Docker, you can enable CUBE OS to gain more capabilities and become more comprehensive and reliable.
<figure><img src="https://67406449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FCnF8kmk9yw3yiy2mRerq%2Fuploads%2F3alLmBBlPXg6jIH4xJ4n%2Fimage.png?alt=media&amp;token=194da3cd-6f53-4bd5-9fe3-cbf033092598" alt=""><figcaption></figcaption></figure>
The following are 2 examples to show how to use the Add-on features on CUBE OS.
## eWeLink Smart Home
Sync eWeLink-supported devices to CUBE and control them. Tutorial refers to: [eWeLink Wi-Fi Devices (LAN Capable)](https://cube.ewelink.cc/getting-started/add-devices/ewelink-wi-fi-devices.md).
## Node-RED
Low-code programming for event-driven applications.
Install and run the Node-Red Add-on.
<div align="left"><figure><img src="https://67406449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FCnF8kmk9yw3yiy2mRerq%2Fuploads%2Fl73Zd2jxOBOzaoAfOf65%2Fimage.png?alt=media&amp;token=d77a22f7-2b6e-415f-ab1b-8ec18a0d919a" alt=""><figcaption></figcaption></figure></div>
Click 'RUN' to open the settings, select network as 'host', and fill in other parameters according to your needs, then tap 'RUN'.
<div align="left"><figure><img src="https://67406449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FCnF8kmk9yw3yiy2mRerq%2Fuploads%2FtVcMG2mICMHOLpQ3vKs4%2Fimage.png?alt=media&amp;token=f0d11812-2d3d-4590-9f7c-0e5b5d366473" alt=""><figcaption></figcaption></figure></div>
Wait a while and open a new browser tab to visit the Node-Red page, the default URL is ihost.local:1880 or IP of iHost:1880 (for example, 192.168.1.232:1880, you may find the IP on your router’s management page.)
<figure><img src="https://67406449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FCnF8kmk9yw3yiy2mRerq%2Fuploads%2F0wFGAXadKt5rhItfcvcN%2Fimage.png?alt=media&amp;token=9961a908-a015-407f-a86b-81787ebc9684" alt=""><figcaption></figcaption></figure>
GET https://cube.ewelink.cc/feature-exploration/docker-and-add-on.md?ask=<question>&goal=<user_goal>
