> For the complete documentation index, see [llms.txt](https://cube.ewelink.cc/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://cube.ewelink.cc/feature-exploration/cast-dashboard.md).
# Cast Dashboard
Cast allows you to create dashboards of your devices and scenes, arm and disarm smart security, and receive your security notifications. On the settings page, simply drag and drop the icons to sort your devices and scenes. Set an access PIN code for the dashboard to prevent unexpected switching.
## **Create your CAST dashboard**
Please visit CUBE OS via browser. Click on the CAST menu on the left side.
<figure><img src="https://67406449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FCnF8kmk9yw3yiy2mRerq%2Fuploads%2Fe9dHrw0Y1lXBa5K7bqP7%2Fimage.png?alt=media&amp;token=b3107306-3dc5-4da2-be69-91f2a4b39b17" alt=""><figcaption></figcaption></figure>
Click the '+' button to create a new dashboard.
Enter a name for the dashboard, select your devices, manual scenes, and charts.
<figure><img src="https://67406449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FCnF8kmk9yw3yiy2mRerq%2Fuploads%2FmpalSekjUaOIzb1DPDzC%2Fimage.png?alt=media&amp;token=542af92b-f8b8-45c8-adb8-509443bc81fd" alt=""><figcaption></figcaption></figure>
On the settings tab, select the widgets you need.
* For the Custom text, please enter your text in the text box.
* Extended CAST  pad layouts for a more flexible dashboard experience.
* Select a background color for the dashboard.
* Set a PIN code for the dashboard if necessary. (If set, when you enter or exit the dashboard, you need to enter the PIN code.)
<figure><img src="https://67406449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FCnF8kmk9yw3yiy2mRerq%2Fuploads%2FWEUguWTDXhUlpS3PAb2V%2Fimage.png?alt=media&amp;token=343fc1fe-5722-4751-aaa4-3e647332e634" alt=""><figcaption></figcaption></figure>
In the preview area, drag and drop the tiles to arrange them. And click the resize icon to change between different sizes.
<figure><img src="https://67406449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FCnF8kmk9yw3yiy2mRerq%2Fuploads%2F9ffK9dkflK8yoAjyT8u1%2Fimage.png?alt=media&amp;token=6f5d34e9-fd9b-4e1b-bed7-ef1cfac704a4" alt=""><figcaption></figcaption></figure>
Click the Save button, and the dashboard is created.
You can visit CUBE's IP/cast to use the dashboard on any web browser (on PC or phone/pad).
<figure><img src="https://67406449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FCnF8kmk9yw3yiy2mRerq%2Fuploads%2FnLcWovNRe8LdTNM1Wu1B%2Fimage.png?alt=media&amp;token=fe124853-865e-451c-b152-c4843323c0eb" alt=""><figcaption></figcaption></figure>
GET https://cube.ewelink.cc/feature-exploration/cast-dashboard.md?ask=<question>&goal=<user_goal>
