> For the complete documentation index, see [llms.txt](https://cube.ewelink.cc/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://cube.ewelink.cc/feature-exploration/automation-and-scene.md).
# Automation and Scene
Learn how to create automations and manual scenes in CUBE OS to make your smart home more intelligent and autonomous.
CUBE OS allows you to create **two types of automations** with your connected devices:
* **Manual Scenes** - triggered manually by the user.
* **Smart Scenes** - triggered automatically based on conditions or device states.
Both types are created in the same interface, but differ in how they are **activated**.&#x20;
{% hint style="success" %}
All automations in CUBE OS run and are **stored locally**, ensuring fast, private, and reliable device interactions without relying on the cloud.
## 1. Manual Scenes
A **Manual Scene** is triggered directly by you - not by sensors, buttons, or schedules.\
It’s ideal for actions you want to activate on demand, like turning on a set of lights or running a "movie mode".
### Example: Turn On a Wi-Fi Lamp and Set Its Color to Blue
Go to **Scene** and click the **"+"** button to create a new scene.
<figure><img src="https://67406449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FCnF8kmk9yw3yiy2mRerq%2Fuploads%2Fr0zjSUrYatujczsCI6Pa%2Fimage.png?alt=media&amp;token=d62cd65c-6057-4ec3-921b-77ddd1ae14e1" alt=""><figcaption></figcaption></figure>
Under **IF**, select **Tap to Run**.
<div align="left"><figure><img src="https://67406449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FCnF8kmk9yw3yiy2mRerq%2Fuploads%2FqZW6ITEV9mln2zzVpTVz%2Fimage.png?alt=media&amp;token=77eaa56d-8dba-458b-92df-cd587dbec824" alt=""><figcaption></figcaption></figure></div>
Under **THEN**, choose **Smart Devices → Wi-Fi Lamp**.
In the lamp options, set:
**Switch** → On; **Color** → Blue
<div align="left"><figure><img src="https://67406449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FCnF8kmk9yw3yiy2mRerq%2Fuploads%2FfK8t1jvrUJVEEbDgkoD9%2Fimage.png?alt=media&amp;token=f5439a8d-9eb9-4765-8eeb-1ed7412f43a7" alt=""><figcaption></figcaption></figure></div>
Save the scene.
Now, whenever you manually run this scene, your lamp will turn on and change to blue.
## 2. Smart Scenes
A **Smart Scene** runs automatically when certain conditions are met, for example, when a motion sensor is triggered or a temperature threshold is reached.
### Example: Turn On the Lamp When R5  Button is Pressed
Go to **Scene → Add Scene**.
Under **IF**, select **Smart Device → SONOFF R5 Button → Click**.
<figure><img src="https://67406449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FCnF8kmk9yw3yiy2mRerq%2Fuploads%2FNEP0S4Z8ItYgvqfkWdCH%2Fimage.png?alt=media&amp;token=1b2ee664-ce79-4366-95e1-503a27055de5" alt=""><figcaption></figcaption></figure>
Under **THEN**, select **Smart Devices → Wi-Fi Lamp → Switch On → Set Color Blue**.
<figure><img src="https://67406449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FCnF8kmk9yw3yiy2mRerq%2Fuploads%2FLos4lF3ofUON0noo1nB3%2Fimage.png?alt=media&amp;token=8fef4abf-138a-468f-89da-d9c216b69825" alt=""><figcaption></figcaption></figure>
Save the scene.
Now, pressing the Zigbee button will automatically turn on your lamp.
You can combine multiple IF and THEN conditions to create complex automations - for example, adding a time condition (Only at night) to the same scene.
## 3. View Automation History
CUBE OS records when each automation was executed.\
To check automation history:
Open the automation you want to review.
<div align="left"><figure><img src="https://67406449-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FCnF8kmk9yw3yiy2mRerq%2Fuploads%2FOvJaJExhHILvZr0oT7kU%2Fimage.png?alt=media&amp;token=c43b674e-c12c-44bb-abff-4ae59d355da4" alt=""><figcaption></figcaption></figure></div>
Click the **History** icon.
Use the **filter** to view events by time or condition.
This helps you monitor whether automations are working as expected.
GET https://cube.ewelink.cc/feature-exploration/automation-and-scene.md?ask=<question>&goal=<user_goal>
