The URL `exploracao-de-recursos/matter-bridge-vincular-aplicativos` does not exist. This page may have been moved, renamed, or deleted.
- [Ponte Matter - Vincular apps](https://cube.ewelink.cc/english-pt-br/exploracao-de-recursos/ponte-matter-vincular-apps.md)
- [Gerencie seu dispositivo](https://cube.ewelink.cc/english-pt-br/exploracao-de-recursos/gerencie-seu-dispositivo.md)
- [Lista de recursos](https://cube.ewelink.cc/english-pt-br/exploracao-de-recursos/lista-de-recursos.md)
- [Sistema de segurança](https://cube.ewelink.cc/english-pt-br/exploracao-de-recursos/sistema-de-seguranca.md)
- [Painel de transmissão](https://cube.ewelink.cc/english-pt-br/exploracao-de-recursos/painel-de-transmissao.md)
GET https://cube.ewelink.cc/english-pt-br/exploracao-de-recursos/ponte-matter-vincular-apps.md?ask=<question>&goal=<user_goal>
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `build a script that syncs our docs to a CMS` lets GitBook tailor the answer to that use case.
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/english-pt-br/exploracao-de-recursos/ponte-matter-vincular-apps.md`).
