The URL `verifica-compatibilita` does not exist. This page may have been moved, renamed, or deleted.
- [Matter](https://cube.ewelink.cc/english-it/controllo-di-compatibilita/matter.md)
- [Zigbee](https://cube.ewelink.cc/english-it/controllo-di-compatibilita/zigbee.md)
- [Aggiungi telecamere compatibili ONVIF](https://cube.ewelink.cc/english-it/blog/aggiungi-telecamere-compatibili-onvif.md)
- [Aggiungi dispositivi](https://cube.ewelink.cc/english-it/per-iniziare/aggiungi-dispositivi.md)
- [Elenco funzionalità](https://cube.ewelink.cc/english-it/esplorazione-delle-funzionalita/elenco-funzionalita.md)
GET https://cube.ewelink.cc/english-it/controllo-di-compatibilita/matter.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/english-it/controllo-di-compatibilita/matter.md`).
