The URL `obzor-funkcii/matter-bridge-svyazat-prilozheniya/apple-home-i-siri` does not exist. This page may have been moved, renamed, or deleted.
- [Apple Home и Siri](https://cube.ewelink.cc/cube-os-ru/izuchenie-funkcii/most-matter-podklyuchenie-prilozhenii/apple-home-i-siri.md)
- [Google Home](https://cube.ewelink.cc/cube-os-ru/izuchenie-funkcii/most-matter-podklyuchenie-prilozhenii/google-home.md)
- [Amazon Alexa](https://cube.ewelink.cc/cube-os-ru/izuchenie-funkcii/most-matter-podklyuchenie-prilozhenii/amazon-alexa.md)
- [SmartThings](https://cube.ewelink.cc/cube-os-ru/izuchenie-funkcii/most-matter-podklyuchenie-prilozhenii/smartthings.md)
- [Мост Matter — подключение приложений](https://cube.ewelink.cc/cube-os-ru/izuchenie-funkcii/most-matter-podklyuchenie-prilozhenii.md)
GET https://cube.ewelink.cc/cube-os-ru/izuchenie-funkcii/most-matter-podklyuchenie-prilozhenii/apple-home-i-siri.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/cube-os-ru/izuchenie-funkcii/most-matter-podklyuchenie-prilozhenii/apple-home-i-siri.md`).
