The URL `decouverte-des-fonctionnalites/pont-matter-lier-les-applications` does not exist. This page may have been moved, renamed, or deleted.
- [SmartThings](https://cube.ewelink.cc/cube-os-fr/exploration-des-fonctionnalites/matter-bridge-lier-des-applications/smartthings.md)
- [Amazon Alexa](https://cube.ewelink.cc/cube-os-fr/exploration-des-fonctionnalites/matter-bridge-lier-des-applications/amazon-alexa.md)
GET https://cube.ewelink.cc/cube-os-fr/exploration-des-fonctionnalites/matter-bridge-lier-des-applications.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/cube-os-fr/exploration-des-fonctionnalites/matter-bridge-lier-des-applications.md`).
